New Feature: Match Closest Array Element
imants_smidchens
Member Posts: 65 EDU
in General
Ever been modeling a configurable part when you realize that different materials, profiles, etc result in different options for length, thickness, diameter, or something else?
Ok in hindsight that's a pretty specific issue to have, but here's a feature that solves those issues regardless:
https://cad.onshape.com/documents/d275f0aa6c54b39d90c74962/w/e885bb4824259a9718e49d84/e/36e1d31aa7ce39ef92db4201
Nice, I've been trying to think of some useful ways to use these array variables. This would be tough to do without this. Ty for sharing!
chadstoltzfus@premiercb.com
Based on this comment, if you're ever going through a very large array, you might want to modify
to be
var size = size(arr); for (var i = 0; i < size; i += 1)I also wonder if any of your comparisons would benefit from using tolerant flavors?Simon Gatrall | Product Development Specialist | Open For Work
Oo - that's clever. Thanks for linking to that discussion! The performance-optimizing-gremlin part of my brain is quite appreciative. Definitely looking into tolerant flavors for a potential improved v2. This got me thinking, heck, might even try doing some regex logic to match similar/identical strings...
