Loft between two circles
sebastian_baltes
Member Posts: 8 ✭
Hi,
I'm new to onshape and want to make something like a loft between two circles, start is:
and the result should be:
Problem is, this results just in a surface and not a solid. If I try this with Solid Loft, I get an error:
Best Regard,
Sebastian
1
MichaelPascoe
Member Posts: 2,681 PRO
Hi @sebastian_baltes, looks like you figured out what you wanted with chamfer. Something to save you some time would be to have one main sketch then revolve the main sketch in a single revolve. Like this:
https://cad.onshape.com/documents/f65231bbdc0c8f95ad85dcc9/w/a1645bb9c148af13df5e42d6/e/10b73ef96ceb09b9a86df437?renderMode=0&uiState=63f8c5a3e47dd059a64e8f2e
If you still want to use the loft technique, it is possible to loft the edges as a surface, enclose the surface with the main part, then boolean them together:
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
