Tapered rectangular hole extrusion
patrick_shea
Member Posts: 63 ✭✭
in General
Just wondering if there is an easy way to to a tapered (on two sides) rectangular hole. I made a sketch, and mirrored the part, but is there a way to do it from my top plane. I only want 2 faces tapered not all 4.
Pat
https://cad.onshape.com/documents/435b0002c3dbf0ea47972e27/w/6d18d5b65fc3af26abf6d9f5/e/799c9943447a1274000733f8
Pat
But what you want is to use the draft feature on the two sides you want tapered (after extruding it straight).
Here is the document again - I made it public
Pat
