*PLEASE HELP* Extruding issue
joaquim_almeria682
Member Posts: 10 ✭
Hi, I am trying to add an extrusion to an existing extrusion, however it appears that the two extrusions aren't merging. Usually when I add an additional extrusion to an existing part, the new extrusion will stay the same color. Not the case here, leading me to believe that they aren't merging despite me using the 'add' extrusion. I need this to be merged together in order to 3D print correctly. Thanks!
(P.S. Images uploaded incorrectly, last image is actually the first and the first listed is the last)
