Hole tool not working
I am sure this is a me problem but I am not seeing it. I went into the help and watched the video but it didn't help. I have a simple rectangular block. I sketched the rectangle and then the construction lines for hole placement, and then extruded the block. I select the intersection of the perpendicular lines where I want the hole (the intersection shows when selected with a "1") to go and then select the hole tool and the intersection is no longer selected. There also seems to be no way to select the face or intersection after the hole tool has been selected. What am I missing?
A "sketch point" can be any of the following:
- Ends of lines, arcs, conics or splines
- Mid-points of lines, arcs, conics or splines
- Centers of arcs or circles
- Virtual sharp of a conic
- An actual sketch point (the little hollow dot)
A circle within sketcher will infer the intersection of two lines (with a pair of coincident constraints), but outside of sketcher I don't think there's any feature which would do the same, without the addition of one of the above.You can't use text corners, or the control points of splines.
