How to mirror element horizontally and then vertically and still keep faces?
otm_cwiotm_cwi Member Posts: 4
edited March 2023 in Community Support
I kindly ask for help with mirroring element. I've got sketch like this:
I can mirror this small element without any issues:
but then, when I try to mirror both of them again using the vertical construction line this happens:
All faces disappear :(
Question:
How can I have those elements copied with everything working as expected - that all faces are still there?
PS I've also tried to use circular pattern (with two elements + two), but the effect is the same...
  • S1monS1mon Member Posts: 3,770 PRO
    The combination of lots of mirrored elements, tangent and offset relations all in a single sketch often doesn't end well. It's probably better to make one of those fingers as a feature (extrude or cut or whatever makes sense for the final geometry), and mirror that.
    While you can mirror and pattern in a sketch, it makes the sketch more complex and not as robust. Mirroring or patterning features or faces is often better.
    If you really want this to all happen in the sketch, it looks like some of the sketch fillets are not coincident and tangent. Either they have gaps or perhaps they are overlapping. It's hard to see in the screen shot with all the constraints turned on. You could share a public document.
    One way to diagnose where the issue is with things being closed is to divide and conquer. Just sketch a temporary line across the entire sketch. If half of it turns into faces, but the other stays clear, then you know which half has the issue. You can drag the line around or add other temporary lines to see where faces can be formed (the sketch is closed).
  • otm_cwiotm_cwi Member Posts: 4
    S1mon, thanks for the answer!
    I'm afraid that for the first time in human history divide and conquer doesn't work ;) I've tried to divide the sketch with multiple lines and no faces appear, no mater what I do and how many lines I draw. I suspect it could be some kind of bug, because I can mirror the part the first time vertically or horizontally - it doesn't matter which axis - and the faces are always showing and the second mirror always makes them disappear... I can even draw some new shapes beside my part and they also do not have faces!
    The document is available here:
