Manually changing number of instances in BOM
kees_bijkerkees_bijker Member Posts: 170 ✭✭
Hello fellow shapers,
Is there a way to manually override the number of instances in the BOM, rather then repeating the insert command numpty times?
Sometimes you do not want to draw all instances of standard fasteners for example, so you draw one and say 46 times. But the BOM is only listing one.
Any way to change this other then export to CSV and do it in a separate spreadsheet?
