Loft projection
ricardo_raimondo
Member Posts: 66 ✭✭
I have the loft in the picture, that I need to project or I should say extend to plane BH 681. Is there any way to achieve that?
eric_pesty
Member, pcbaevp Posts: 2,589 PRO
If you want to "extend" you could use a "move face" up to your plane.
If you want to project, you could extrude the end face up to the plane.
You could also sketch on your plane and do a "use" to convert the end face of the loft depending what you are trying to do...0
