3DConnexxion mouse not working proper
ton_tiggeston_tigges Member Posts: 4
Since several weeks my 3DConnexxion mouse doesn`t  work proper anymore. I can only zoom in and out. The other functions are dead. I have checked the mouse driver and this looks good.
What can this be??
  • MichaelPascoeMichaelPascoe Member Posts: 2,380 PRO
    When mine doesn't recognize Onshape, I usually exit the browser, then unplug and plug my device receiver. If this doesn't work, I go to where the driver is installed and stop then start the driver manually with the stop.exe and start.exe files if they gave them to me in that version of the driver.
    Stop drivers > close browser > unplug device > plug device back in > start drivers > open browser again
  • ton_tiggeston_tigges Member Posts: 4
    It`s working again. I was way behind with driver updates. Doewnloaded the latest driver and restarted and it`s working again. Thanks for the help.
