Is it possible to group several customfeatures in a toolbar dropdown?
roman_jurt190
Member Posts: 46 EDU
in General
Hi! My custom feature collection is quite large and i'd like to arrange them in dropdown-themes (like: pattern features, 3d-printing helpers...). Onshape standard-features are often sorted in dropdowns - while i can rearrange custom features in the toolbar, i can't create new dropdowns and i can't place them in existing dropdowns... putting them into the shortcut toolbar is no solution either...
and to make things worse: We run EDU ENTERPRISE... and all the nice icons of all the feature scrips do not show...
Has anyone a solution to this? thank you!
eric_pesty
Member, pcbaevp Posts: 2,529 PRO
Toolbars will automatically "collapse" as you shrink your window, the ones on the left side will be expanded until it "runs out of room".
However you cannot currently "permanently" stack features like the standard "thicken/enclose" or "linear/circular/curve" pattern are so the best you can do is group them in a "toolset" and keep the "most important" ones further to the left.
I have found I have so many custom features I've kind of given up find myself using the search function to find them more and more and just browse around my toolbars when I don't remember what one is called!
Improvements to Onshape - February 3rd, 2023 — Onshape
I also would like custom feature drop down menus.
Currently this is not possible, but there is an improvement request you can vote for here:
https://forum.onshape.com/discussion/12610/menu-groups-pull-down-name-icon
I'm not sure how to fix the enterprise custom feature icon issue. I think it's happening because everything is being routed through the custom domain instead of cad.onshape.com. If you go and copy those custom feature documents so that they are in your own domain, then it will show the icons. However, this will break the links to the original author and you wont get feature updates for those custom features.
So you need a really wide window (and also reduce the zoom way down), then you can customize and drag buttons, including a "new toolbar" area on the far right.
This is a comically broken area of the UI in Onshape...
One critical piece of information: make sure you don't move the "add custom feature" button, otherwise newly added custom features won't show up in any toolbars!
Like this:
https://forum.onshape.com/discussion/18099/named-toolbars
