Loft projection
ricardo_raimondoricardo_raimondo Member Posts: 66 ✭✭
I have the loft in the picture, that I need to project or I should say extend to plane BH 681. Is there any way to achieve that?
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,475 PRO
    If you want to "extend" you could use a "move face" up to your plane.
    If you want to project, you could extrude the end face up to the plane.
    You could also sketch on your plane and do a "use" to convert the end face of the loft depending what you are trying to do...
  • EvanReeseEvanReese Member, Mentor Posts: 2,695 PRO
    In addition to Eric's good suggestions you could use "Replace face" with the plane as the face to replace with.
  • ricardo_raimondoricardo_raimondo Member Posts: 66 ✭✭
    I guess that "extend " should have been the correct word. I will try your suggestion. Anyways, I solved the problem by scaling non-uniformly. Well let you know if I reach the same part using the "move face" feature, which I never used before, and seems the right way to do this.
    Thank you, guys. The "move face" was exactly what I need for this case. I will check at a later time the use of the "replace face" as suggested. Will not hurt to learn something else.
