Copy and paste mobile ios
Sleepyhead
Member Posts: 19 ✭✭
I can not find how to copy and paste a part on the mobile App, specifically iOS. I have found tutorials for computer onshape.
S1mon
Member Posts: 4,063 PRO
@robin_harper672
Are you trying to copy/paste in a part studio or an assembly?Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
In using Transform, you could copy a part IN PLACE, and that means that it’s going to duplicate that part at the exact location of the original. When doing it this way, you’ll want to look at the Parts List on the left side of the screen, and you may want to ghost the original part, in order to see the new part
With Transform, you could also copy a part to a different location. And also to a different orientation
There are a number of things to choose from within the transform dialog box
Aside from Transform —
You could use MIRROR, to end up with a copy that is a mirrored geometry of the part
There’s also ways of copying a part by using one of the pattern tools. Such as linear pattern, circular pattern, or curve pattern, or a custom featurescript pattern tool
Back to the Transform tool —
Here is an example of using Translate by XYZ within the Transform tool
