How do I invoke the Sketch toolbar?
stanley_max
Member Posts: 6 EDU
HI Onshape colleagues,
Could someone please explain to me how to invoke the Sketch toolbar? In other words, how do I get the Sketch toolbar to show.
Thank you.
Stanley
- Member of the U.S. Metric Association, which has certified me as a Metrication Specialist.
- Member of the National Association of Rocketry, in which I have reached Level-1 in certification in high-power rocketry, where Level 3 is the highest classification.
When you open Onshape, you will see the Features toolbar at the top (Extrude, Revolve, etc.). Click Sketch and then sketch one of the planes, Front, Top, or Right. That will change the toolbar at athe top from the Features toolbar to the Sketch toolbar. When you complete the sketch, you'll be back to the Features toolbar.
cheers,
matt
Sounds like you might want to spend just a little time watching some of the training videos. There are keyboard shortcuts for many of the things that you want.
It's also not really clear what you are expecting. This is not Autocad. Onshape is for 3D parametric collaborative mechanical CAD. While you can do things that are just 2D, or work non-parametrically, or work by yourself, or work on things that are organic, or whatever... Onshape is made for very specific types of work.
https://cad.onshape.com/help/Content/shortcut_keys.htm
https://learn.onshape.com/courses/introduction-to-part-design
https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22CAD%20Basics%22%5D
https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22Onshape%20Fundamentals%22%5D
Below are a couple ways that are painless and not torturous
To add to what Matt, Simon, and Mahir have said, if you haven't made any sketches yet, you can click on a plane or mate connector, and then click on the SKETCH button, and this will also bring up the Sketch Toolbar without having to sketch anything. Actual time is less than a second to do. The GIF is slower than realtime,
If you've already made a sketch, you can bring the toolbar up by double clicking on its' name in the Features List, and this will again show the toolbar
Actually, what @steve_shubin wrote particularly helped me. I didn't realize that you had to double click on the name, and doing that invokes the Sketch toolbar.
Right-click => edit also works...
Now I have to click the green tick icon, in order to continue.
The effect is: Sketch Toolbar disappears.
And if this happens on the second step of the first lesson - how is it going to continue?
Maybe you want to try that yourself?
Twitter: @BryanLAGdesign
One might consider explaining that in the video, obviously I am not the only one stumbeling over this.
