How do I contact the owner of a public document?
StephenGStephenG Member Posts: 383 ✭✭✭
I should be able to use Onshape's Forum messaging (mail) system but when I enter the document owner ID in the recipient(s) field it is not recognized as a valid/existing user.
This gives me the impression that only "registered" forum members can be contacted. It has been years since I acquired an Onshape account ID and I cannot remember if I had to sign up separately to access the forums.
Is it possible to declare oneself as noncontactable?
  • john_rousseaujohn_rousseau Member, Onshape Employees, Developers Posts: 417 image
    Hi @StephenG. I was referring to contacting owners of public documents. You definitely can contact users here on the forum once they have logged in once.
    There are privacy concerns with publishing the creator or owner of a public document. We don't provide any mechanism to do that.
  • S1monS1mon Member Posts: 3,768 PRO
    In the case of popular custom Featurescripts, it would be great if there was an obvious way for creators to optionally include contact info. Of course they can write whatever they want in the intro PDF and they could put stuff in comments in the source code, but it would be great if there was a consistent way to include a contact.
    For documents with parts, it would could be helpful as well to allow a similar option.
  • StephenGStephenG Member Posts: 383 ✭✭✭
    @john_rousseau
    Your answer doesn't seem to be accurate because names of OS users appear in a popup to select from. I did a little experiment. I tried sending a message to an OS user that has never accessed the OS forum. User never was not notified of the email. Had that OS user go into the OS forums. Forum detected this was the user's first time accessing the forum and congratulated him. Now that OS users ID shows up in the recipient popup to select from.
    It appears you cannot send a message to another OS user via the forum messaging tool unless the user has previously accessed the forum.
