Assembly configurations - easy selection with multiple possible combinations
Sebastian_Isted
Member Posts: 4 PRO
Hi,
I'd like to configure parts in an assembly to make the overall component easily customisable with a different selection of parts. The component is a frame that houses multiple glands of varying types and sizes. I would like it possible that each slot that houses a gland can be selected and the gland type/size chosen from a drop down menu. This would enable, for example, someone to choose gland 4 in slot 2 and gland 13 in slot 5, whilst leaving the others empty or with blanking glands.
Currently, I can only figure out how to configure it such that each possible combination is a selectable configuration option. But with several gland types/sizes and multiple slots, the number of combinations is vast and hard to define. Hence a dropdown for each slot would make selecting the desired glands easier. Any ideas?
Thanks
Thanks
eric_pesty
Member, pcbaevp Posts: 2,474 PRO
You can just create a drop down for each "location" with the relevant options or am I missing something?
like this:
https://cad.onshape.com/documents/257cc63ddb87f627dcfc6488/w/d8fb6cb698fca6e012eeb6e1/e/33f33fb2f393b4eb04fe96ec?configuration=default&renderMode=0&uiState=640cbaafe6bb1a0c6cda8ec9
I created a sub-assembly with the different options to make it "easier to manage"1
like this:
