get featureList of parent feature from a query?
EvanReese
Member, Mentor Posts: 2,865 PRO
How can I take a query of a sketch edge, and get the featureList of the parent sketch? I know how to get the sketch Id, but I'm not sure where to go from there.
_anton
Member, Onshape Employees Posts: 526
So you want the feature id?
https://cad.onshape.com/documents/19d37a12b586bed2588d0cd3/w/2b3260397b1c17b89cecdaf6/e/e7b403c016b91174c135d374
1 -
Jacob_Corder
Member Posts: 141 PRO
@Evan_Reese
Are you just trying to copy the sketch?
this does it and keeps it as a sketch
probably add construction filters if you want.FeatureScript 1977; import(path : "onshape/std/common.fs", version : "1977.0"); annotation { "Feature Type Name" : "pattern Sketch" } export const patternSketch = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "sk Ent", "Filter" : EntityType.EDGE||EntityType.FACE, "MaxNumberOfPicks" : 1 } definition.skEnt is Query; } { var owner = lastModifyingOperationId(context, definition.skEnt) as Id; owner = owner[0]; owner = makeId(owner); opPattern(context, id+"Copy", { "entities" : qCreatedBy(owner, EntityType.BODY), "transforms" : [identityTransform()], "instanceNames" : ["copySketchEnts"] }); });2
Thanks. I've gotten that far, but I'm wanting it formatted in whatever form applyPattern() ingests. I thought I might need to use featureList(), but I'm not sure.
Something like this:
applyPattern(context, id + "copySketch", { "instanceFunction" : sketchId, "patternType" : PatternType.FEATURE, "transforms" : [identityTransform()], "instanceNames" : ["copy"], "fullFeaturePattern" : false }, identityTransform());The Onsherpa | Reach peak Onshape productivity
FeatureScript 1977; import(path : "onshape/std/common.fs", version : "1977.0"); annotation { "Feature Type Name" : "pattern Sketch" } export const patternSketch = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "sk Ent", "Filter" : EntityType.EDGE||EntityType.FACE, "MaxNumberOfPicks" : 1 } definition.skEnt is Query; } { var owner = lastModifyingOperationId(context, definition.skEnt) as Id; owner = owner[0]; owner = makeId(owner); opPattern(context, id+"Copy", { "entities" : qCreatedBy(owner, EntityType.BODY), "transforms" : [identityTransform()], "instanceNames" : ["copySketchEnts"] }); });Thanks for seeing through my wrong question and giving me the answer to the one I should have asked. That does accomplish what I'm after. I had done something similar, but I guess different enough to mess up other feature's ability to find the sketch plane direction. This should unblock me on what I'm working on!
