get featureList of parent feature from a query?
EvanReeseEvanReese Member, Mentor Posts: 2,519 PRO
How can I take a query of a sketch edge, and get the featureList of the parent sketch? I know how to get the sketch Id, but I'm not sure where to go from there.
  • Jacob_CorderJacob_Corder Member Posts: 138 PRO
    @Evan_Reese
    Are you just trying to copy the sketch?
    this does it and keeps it as a sketch
     probably add construction filters if you want.
     FeatureScript 1977;
    import(path : "onshape/std/common.fs", version : "1977.0");
    annotation { "Feature Type Name" : "pattern Sketch" }
    export const patternSketch = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "sk Ent", "Filter" : EntityType.EDGE||EntityType.FACE, "MaxNumberOfPicks" : 1 }
            definition.skEnt is Query;
            var owner = lastModifyingOperationId(context, definition.skEnt)  as Id;
            owner = owner[0];
            owner = makeId(owner);
            opPattern(context, id+"Copy", {
                    "entities" : qCreatedBy(owner, EntityType.BODY),
                    "transforms" : [identityTransform()],
                    "instanceNames" : ["copySketchEnts"]
    edited March 2023
    @_anton is close, but to get the sketch features id you need take the first element in the id. So ownerSketchId[0] should do it.
  • EvanReeseEvanReese Member, Mentor Posts: 2,519 PRO
    edited March 2023
    @_anton
    Thanks. I've gotten that far, but I'm wanting it formatted in whatever form applyPattern() ingests. I thought I might need to use featureList(), but I'm not sure.
    Something like this:
    applyPattern(context, id + "copySketch", {
                        "instanceFunction" : sketchId,
                        "patternType" : PatternType.FEATURE,
    		    "instanceNames" : ["copy"],
                        "fullFeaturePattern" : false
                    }, identityTransform());
    @Evan_Reese
     FeatureScript 1977;
        precondition
            owner = owner[0];
    @Jacob_Corder
    Thanks for seeing through my wrong question and giving me the answer to the one I should have asked. That does accomplish what I'm after. I had done something similar, but I guess different enough to mess up other feature's ability to find the sketch plane direction. This should unblock me on what I'm working on!
    @_anton is to receive credit, I didn't even think of using lastModificationFeatureId to extract it. I was surprised that opPattern actually copied the sketch as it is. I just tested it to see what would happen and boom a sketch.
  • _anton_anton Member, Onshape Employees Posts: 481
    Team effort. :P
    Go team!
