Symbols
Is there a way to add symbols such as the diameter symbol in text? Like if I wanted to add a second line of text to a leader and wanted to start this second line off with the dimension symbol how would I do it. It would be nice to have a symbol set to pick from for adding commonly used symbols when typing in text.
There are no symbols at this time but would be a good request.
I've been creating symbols by using the alt characters.
I mostly use alt +232 for the diameter symbol.
I've noticed that you must have a character after this for it to work, so I just use the space bar.
At least this is the case in the pre-dimension text box.
If you attempt to use the alt characters while creating notes you will find that some fonts will not accept these characters, the DejaVu fonts will.
See below for a link to more alt characters. Instructions for use are at the bottom of linked page.
http://www.tedmontgomery.com/tutorial/altchrc.html
Thanks
