Can I add a blank dimension
derek_westwood
Member Posts: 34 ✭✭
Can I add a blank dimension in a layout I want to finalize or do I have to get the tippex out?
MichaelPascoe
Member Posts: 2,812 PRO
Yes. To make sure we are on the same page, you must insert your Part studio or Assembly studio into a Drawing studio first. Then, place a dimension on the part. Next, edit the dimension, then put some spaces in there. There are settings to show modified dimensions with an underline; this can be changed so that there is no underline when you modify dimensions.
RENDERCAD
________________________________________________________________________1
RENDERCAD
