In the Assembly page, how do you lay a part parallel to a plane?
jeffrey_ozanne
Member Posts: 3 ✭
When I export my part as an STL for 3D printing, it's slightly slanted and lifted off of the build plate. How can I fix this problem without manually laying the part flat in Prusa Slicer every time?
Would it just be easier to start the assembly from scratch and fix one of the parts in place before doing anything else?
S1mon
Member Posts: 4,079 PRO
Are you exporting from a part studio or the assembly? Is it in the correct orientation in the part studio?
You could fix orientation issues in the part studio with Transform, and/or you could fix things in the Assembly using appropriate mates. It's a little hard to be more specific without images or a public model.Simon Gatrall | Product Development, Engineering, Design, Onshape | Ex- IDEO, PCH, Unagi, Carbon | LinkedIn
1
Thank you for the additional tips that'll be useful.
Here is the public part under the Wire Wrap Assembly tab: https://cad.onshape.com/documents/c470e1cb9cf022a1b6d17ba0/w/ddf11c7eca69d41f3a033add/e/c74d97e691bd9cd0a734574c
