Wave diffuser feature script
2»
  • steve_shubinsteve_shubin Member Posts: 1,118 ✭✭✭✭
    edited April 2023
    That’s going to end up with a different number of parts. I’ll take care of that probably at the end of the day because I have stuff I have to tend to now
    edited April 2023
    https://cad.onshape.com/documents/c8c85a344d2bc352c93c3123/w/c12cef3bd1a260ea9d394378/e/558658ce897e3978fc35e937
    In trying to get the spacing at 40 and the thickness at 22, using transform was going to be too slow with regards to how I laid out my features. So I went back and modified a number of features to get it to your 3600 x 2500 with a 40 on the space and 22 on the thick. In doing so, I ended up with the original amount of full rings around the center hump.
    With a spacing of 40mm and a thickness of 22, you’re not going to end up exactly with 3600mm. It’s going to be a tiny bit less.
    58 X 62 - 40 = 3556
    About 7/8 of an inch shorter on each end
    Spend some time slowly rotating left to right and compare it to that with the original aspect ratio
  • jacek_zagajajacek_zagaja Member Posts: 47 ✭✭
    edited April 2023
    Machining cost 500$ in workshop or 230$ by friend, material probably another 500$. Machining will be ready at the begining of May.
    My friend got shingles and project is postponed.
    Friend has cancelled because flat owner refused to install this diffuser.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 985 ✭✭✭✭✭
    Would have been cool to see the final product installed.
    Bryan Lagrange
    Twitter: @BryanLAGdesign
    edited August 2023
    Finding new "investor" will take time. Meanwhile I'm going to try model and machine "texture" like this. (help appreciated). 53x63cm, 10mm deep, 25mm MDF.
