const string value as map key?
imants_smidchens
Member Posts: 73 EDU
Hi! I'm working on a featurescript that has a lot of maps for user inputs/calculations, and to keep things clean & organized, I've moved all the maps to a separate feature studio, which I then import.
To make things more robust & future proof, I'm defining some strings (which will be used in keys later) as constants, but unfortunately Featurescript insists that it can't find a key then.
for example:
If I use strings for the keys, it works fine, but changing them to variables, even when wrapped in parentheses, results in the Feature Studio that imports these tables saying "Map entry has no key"
supposedly this should be allowed....
any suggestions?
for example:
const a = "foo";
const b = "bar";
export const DemoTable = {
"name" : "table",
"displayName" : "table",
"default" : (a)
"entries" : {
(a) : "chose foo",
(b) : "chose bar",
}If I use strings for the keys, it works fine, but changing them to variables, even when wrapped in parentheses, results in the Feature Studio that imports these tables saying "Map entry has no key"
any suggestions?
and a missing a semicolon at the end. Public doc version that shows the error?
So lookup tables specifically require their maps to be listed with literal string keys, not an arbitrary FeatureScript expression.
