How can I prevent a perpendicular constraint or plane from reversing orientation on model changes?
james_howard360
Member Posts: 28 PRO
I'm relating sketches to the terminating point of a helix, including a tangential line, and I need the revolution count to be configurable, but the relations flip depending on the revolution count. If I model at 12 revolutions, then change to anything between 12 and -12.49 the relations hold. If I change to anything between 12.5 and 12.99, the direction of the sketched line flips due to the ending angle being greater than 180deg. I don't know which element is flipping (sketch plane or perpendicular line relation).
Is there a proper method to prevent this behavior, and is there a way to tell the difference between Side A and Side B of a plane to troubleshoot?
Sample document: test helix relations | Part Studio 1 (onshape.com)
S1mon
Member Posts: 3,460 PRO
Again, I'd really have to fight with Onshape myself to check, but Mate Connectors have options to re-align the primary or secondary axis. If you use those, you might be able to use something that won't change with the helix.
@S1mon I just tried the mate connector, but unfortunately when defined the connectors have an attachment point and a fixed orientation, so a related sketch would always point in one direction regardless of the helix end angle.
That did give me an idea, though. I had been setting the tangent line perpendicular to the plane, and instead drew a new line from the cylinder axis to the helix endpoint and used that as the perpendicular reference; now it works as intended.
The plane must have been reversing its orientation re the helix end point or the sketch relation. As far as I can tell, planes have no defined front/back so the solver doesn't seem to care - that might also explain why there are so many issues with sketches that get flipped when redefining sketch planes.
Thanks
