Standard Content Rivet
Looking to insert a rivet into a multi part studio to check clearance.....I see references to "Standard Content"....but can not seem to find it.......I searched "learning center" and "Standard Content".....I expect it is a derived part....much of the public content is in assemblies.....Is it part of the Onshape data ...is it outside source (McMaster Carr) or public documents?
glen_dewsbury Member Posts: 1,042 PRO
Standard content is in the assembly. If you work in context from assembly to part studio, then you will see it shaded.1 -
nick_papageorge_dayjob Member, csevp Posts: 961 PRO
Standard content is here. Rivets are not included in it. You'll have to get them from McMaster as a STEP and import into OS, or, hand draw them.
1
Once in the assembly, you can take a cross section of the rivet (or hole the rivet goes in). Then you can see the clearance between the parts and the rivet. If it needs adjustment, you'd go back to the part studio of the parts and adjust the hole diameter there. Or, get a smaller diameter rivet and insert it into the assembly instead.
There is also interference detection in assembly that is super helpful.
Happy modelling.
https://cad.onshape.com/documents/7f0125bda4a083823df3fa81/w/2e76673e2fd8a34cb75d0a8f/e/e217cd7272d0879a9cd3e2b1?bomType=structured&renderMode=0&rightPanel=BOMPanel&uiState=64331fd6de754903868888a1
