How to get a flat pattern for the top deck of a curved surfboard model
2»
  • 7Cs7Cs Member Posts: 7
    Hello there! Is there any new method regarding flattening? Thanks!
  • EvanReeseEvanReese Member, Mentor Posts: 2,516 ✭✭✭✭✭
    not for compound surfaces, no. If it's a developable surface (one that bends but doesn't stretch, like paper), then sheet metal tools should be able to do it (here's an example). I'd use Rhino if I needed compound surface flattening, and Exact Flat is a tool i've never used, that might be even better suited, esp given that they have a plugin for Rhino.
  • justin_hodgesjustin_hodges Member Posts: 9 PRO
    Any update? This would be super useful if OS had this feature
  • S1monS1mon Member Posts: 3,460 PRO
