Mirror component in assembly
ConorConor Member Posts: 2
I see that it is possible to make a circular or linear pattern of a component in assembly, but what if I want to mirror those components instead in assembly? Is that currently possible?
  • CBowersCBowers Member Posts: 50 PRO
    It is not
    If your part studio is just a single part I would suggest making a configuration that mirrors the part in the part studio. If there is more than a single part present, you can derive the part you want to mirror into a separate part studio and mirror it there.
    It is not
  • AngleCAngleC Member, pcbaevp Posts: 12 PRO
    edited March 2023
    A work-around that I have used successfully in such a case is to use a circular pattern with a rotation angle of 180 degrees and a pattern quantity of 2X.  The axis of rotation is first created midway between the original and the "mirrored" instance.
  • Lucas_KuhnsLucas_Kuhns Member, csevp Posts: 105 PRO
    This is one of if not the highest voted improvement request. You can add your vote here: https://forum.onshape.com/discussion/5763/mirror-feature-for-assembly-workflow/p1
