How do you make indentations on both sides of a surface?
I'm trying to create a part that will be a flat surface with indentations on both sides. So if you looked at either side, you'd see some bumps and indentations. A bump would correspond with an indentation on the other side. After a day of trying, I haven't been able to do it. I found this thread: https://forum.onshape.com/discussion/10382/indentation but I can't understand how they reached the final product. Could someone give me an outline the steps needed? I can create the flat surface and extrude it, with holes for where the bump/indentations will be, but I'm stuck at that point.
Independent Onshape Consultant
