Loft between two sketches with identical number of points fails
I have created two sketches on parallel construction planes. Both sketches were created with the same feature script function and have identical number of points - just the distances between these points is differently parameterized.
I now want to create a loft between these two sketches. Initially I thought this should be easy for the lofting algorithm (associating one point from the one sketch to the corresponding point in the other sketch), but apparently the heuristic works differently than anticipated and it fails to compute meaningful guiding rails (or to even loft anything at all). Particularly as the two sketches are parametric I would prefer not to manually fix all the guiding rails (as this would break as soon as I change the parameters of the sketches). Is there a way to successfully loft the two sketches? (I also have a programmatic "opLoft" call attempt inside the Featurescript - there I just get "INVALID LOFT", so I have commented it out and tried to make the loft manually for now - which also didn't work). Any ideas?
Here my example in Onshape: https://cad.onshape.com/documents/5ea9f7c73950b1b31a35cd0b/w/5a103984d7642b913ea7650d/e/63e92a25a51b5ab7d32910d6?renderMode=0&uiState=643525a4441f320a398c798b
If you're careful with connections, you can add them and get this:
https://cad.onshape.com/documents/91d6541753a3e6e0e2d8099e/w/8a8c8a2bc97528899bf5ac95/e/ac55171c0990652411d05d8a
I would consider splitting the edge of each "internal corner" in the front section.
