Assembly reference the current working version of instances from different documents.
Just wondering if it's possible to avoid having to continuously right click and hit "update" if there is a new version available. Is there a setting where it automatically pushes the newest version?
nick_papageorge_dayjob Member, csevp Posts: 1,019 PRO
No, it's not possible if you are working across different documents. If all the studios you are pulling parts/assy's from are within the same document, then they update instantly as the default action.1
Onshape's references are very robust, and you move move tabs around without any trouble.
Here are a couple places to explore for more information:
Working with Documents: https://jps.onshape.com/help/Content/docmanagement.htm?tocpath=Document Management|_____0
Working with Tabs (and moving them around): https://jps.onshape.com/help/Content/elementtabs.htm?Highlight=moving tabs
In-Context design (if this is useful for you): https://learn.onshape.com/courses/managed-in-context-design
Good luck!
