Extruding Text
I added a text box with text on a separate sketch, and it extruded normally. But if I add several text boxes to the same sketch, Onshape will not select the text or text box to be extruded. Instead, it selects and extrudes the surrounding faces and sketches. How can I select and extrude particular text on a sketch with several text boxes? Thank you.
nick_papageorge_dayjob Member, csevp Posts: 956 PRO
https://cad.onshape.com/documents/d8325e2df1d84a7c42014cb3/v/653b4530e72b6e804feab88c/e/d087338901cc7df805540cf3?renderMode=0&uiState=6441f3f9eb31156ab9b55cab
https://cad.onshape.com/documents/d8325e2df1d84a7c42014cb3/v/8cd788be0298f013bc50fa64/e/d087338901cc7df805540cf3?renderMode=0&uiState=644287a2e8cdba79ed6c2367
