Connecting tubes/round things
Huge noob here so please bear with me. Considering I didn't know how to spell CAD two weeks ago, I'm getting along well enough to satisfy myself. Admittedly my personal satisfaction level is low, but regardless, I'm happy but now need some help on this journey. I've looked around but I guess I'm not using the correct words to get an answer I can under stand.
The setup: The picture below is of one small diameter tube and one larger diameter tube. As you can see the parts aren't exactly tubes but the principle would be the same. Flat but of the smaller tube trying to become attached tot he larger tube.
As you can see below I've gotten them "together" but not sure how I did it to be honest and there must be a way that is dead simple? And to add to it all, once they are together I'd like the larger part to allow flow into the other tube? Make sense? These pictures are what I'm dealing with if it helps.
Looking inside the larger part below, you will notice that the smaller blue tube pokes through the larger purple part as you'd expect but not what I'm looking for. I'd like the blue part to fit itself to the curve of the purple part without any protrusions.
Once the parts are together I need them to allow flow between them selves. Once mated,
this can be all one part. I made two parts since I didn't know how to create the part all at once.
I do try to find answers before dragging others in, but since all is so new, the words I've used to date bring up all kinds of ways to mate things, but not this for example. Yes, I'm plenty ignorant of this CAD stuff but had to start somewhere. Regardless of my frustrations, I'm really enjoying it. TY all in advance. PC
kevin_wood958 Member Posts: 9 ✭
Welcome to a fellow noob designer. Assuming I'm understanding what you're end goal is, this should be a pretty easy solution. One, have you used the boolean feature at all? If not, it's what's needed to combine multiple parts into one. So, my thought to achieve this would be as follows.- Extrude the smaller tube up to the face of the larger tube
- Use the boolean feature to merge them into a single part (you can possibly skip this step if you elect to "merge with all" when extruding in Step 1)
- Extrude your desired hole size into the larger tube where the two tubes have mated
1 -
glen_dewsbury Member Posts: 1,164 PRO
@price_cobb
A discreet boolean is not required. The second feature can be an extrude/add. Look at extrude2. The second end position is up to face which stops the stick through.
https://cad.onshape.com/documents/4ca0229f69e5013bbd25e104/w/0721279ba72bb0e922174b8e/e/d37fc40f2404d5b5fc75da9c
I followed the above steps to produce the part below. Not identical to your part or as refined. But sounds like it's what you're trying to achieve.A discreet boolean is not required. The second feature can be an extrude/add. Look at extrude2. The second end position is up to face which stops the stick through.
However, there has to be a faster way even if it all becomes exponentially faster just by doing.
Can't thank you enough for chiming in. Greatly appreciated! Have a wonderful weekend. PC
