Inspection Item each line in a text box (COULD AN ADMIN PLEASE MOVE THIS TO REQEUSTS PLEASE)
Nath_McCNath_McC Member Posts: 135 PRO
edited April 2023 in Drawings
I want to suggest that we be able to add an inspection item number for each line on a text block.
I have a notes block with multiple numbered points, and I can not add an inspection number to each line and have it link.
The work around would have to be adding a separate text item for each line to separate it.
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 565 image
    @Nath_McC We do intend to do exactly that, we are just not there yet.  We would like for lists in notes to be able to have an inspection item assigned per numbered/lettered note list item.  I have created a ticket and tied your ticket to that improvement.
  • Nath_McCNath_McC Member Posts: 135 PRO
    Brilliant. Thank you for the update.
