OnShape API GET request for a gltf object for assemblies
earlgreyaroma
Member Posts: 4 EDU
in General
Hi,
is there a way to get a gltf object from a whole assembly (the parts should be displayed assembled) directly or with some tricks? I couldn't find anything in the glassworks explorer except for getting singular parts gltfs and my knowledge in web development and this kind of stuff is lacking. Thanks in advance.
You can use the https://cad.onshape.com/glassworks/explorer#/Assembly/translateFormat to export an assembly to GLTF. The format name is "GLTF", for example
curl -X 'POST' \ 'https://cad.onshape.com/api/v5/assemblies/d/a270d298dcd5eddb8f8df87a/w/0f9427c5999a5208c1aaf723/e/97fbc083912b777dca988f90/translations' \ -H 'accept: application/json;charset=UTF-8; qs=0.09' \ -H 'Content-Type: application/json;charset=UTF-8; qs=0.09' \ -H 'X-XSRF-TOKEN: 24Ps+OlFRwV4iXJeiFWsSQ==' \ -d '{ "allowFaultyParts": false, "angularTolerance": 0.01, "distanceTolerance": 0.01, "formatName": "GLTF", "importWithinDocument": true, "maximumChordLength": 0.01 <span>}'</span>Hope that helps!
Paul
For example Once you do this, the response will include a URL to poll for the status of the translation (the translation isn't instantaneous). Once the requestState is "Done" , you can use the `resultExternalDataIds` to download the data using the API , https://cad.onshape.com/glassworks/explorer#/Document/downloadExternalData.
Note: resultExternalDataIds maps to fid in the downloadExternalData request. For more information: https://onshape-public.github.io/docs/translation/#general-translations
