OnShape API GET request for a gltf object for assemblies
earlgreyaromaearlgreyaroma Member Posts: 4 EDU
Hi,
is there a way to get a gltf object from a whole assembly (the parts should be displayed assembled) directly or with some tricks? I couldn't find anything in the glassworks explorer except for getting singular parts gltfs and my knowledge in web development and this kind of stuff is lacking. Thanks in advance.
  • Paul_J_PremakumarPaul_J_Premakumar Member, Onshape Employees Posts: 235 image
    Hi,
     You can use the https://cad.onshape.com/glassworks/explorer#/Assembly/translateFormat  to export an assembly to GLTF. The format name is "GLTF", for example
    curl -X 'POST' \
      'https://cad.onshape.com/api/v5/assemblies/d/a270d298dcd5eddb8f8df87a/w/0f9427c5999a5208c1aaf723/e/97fbc083912b777dca988f90/translations' \
      -H 'accept: application/json;charset=UTF-8; qs=0.09' \
      -H 'Content-Type: application/json;charset=UTF-8; qs=0.09' \
      -H 'X-XSRF-TOKEN: 24Ps+OlFRwV4iXJeiFWsSQ==' \
      -d '{
      "allowFaultyParts": false,
      "angularTolerance": 0.01,
      "distanceTolerance": 0.01,
      "formatName": "GLTF",
      "importWithinDocument": true,
      "maximumChordLength": 0.01
    <span>}'</span>
    Hope that helps!
    Paul
  • earlgreyaromaearlgreyaroma Member Posts: 4 EDU
    Thank you very much. The translation part works perfect now. I can manually download a working gltf file now. But my initial goal is to get back a json similar to the get requests for the part and partstudio gltf objects. I've read on other threads that I can use this with the generated translation ID to get the data:
    But it returns a 403 response with a message saying I either don't have permissions or the file doesn't exist, which both is wrong. Or do I need to add something into the request body of the translation request? I will be very grateful if I could get further help.
    edited April 2023
    You will need to set "importWithinDocument" : false to avoid downloading the file in the document.
    For example
    curl -X 'POST' \
      -H 'X-XSRF-TOKEN: EXO5O05ZGmIgxM5hPQQtEg==' \
      -d '{
    "maximumChordLength": 0.01,
    "storeInDocument" : false
      Once you do this, the response will include a URL to poll for the status of the translation (the translation isn't instantaneous). Once the requestState is "Done" , you can use the `resultExternalDataIds` to download the data using the API , https://cad.onshape.com/glassworks/explorer#/Document/downloadExternalData.
     { "requestState" : "DONE", "requestElementId" : "97fbc083912b777dca988f90", "resultExternalDataIds" : [ "644a6a544029fb275b67b7f6" ], "versionId" : null, "documentId" : "a270d298dcd5eddb8f8df87a", "workspaceId" : "0f9427c5999a5208c1aaf723", "resultElementIds" : null, "resultDocumentId" : "a270d298dcd5eddb8f8df87a", "failureReason" : null, "resultWorkspaceId" : "0f9427c5999a5208c1aaf723", "name" : "Assembly 1", "id" : "644a6a523cb91475814d44fe", "href" : "https://cad.onshape.com/api/v5/translations/644a6a523cb91475814d44fe" }
     Note: resultExternalDataIds maps to fid in the downloadExternalData request. For more information: https://onshape-public.github.io/docs/translation/#general-translations
