Move Face Limitations?
Curious about a move face command that will not execute. Are there limitations? Perhaps constraints? Works fine on a simple shape in another part studio but not the part I would like to move a face on.
Thank you
Thank you
With a little practice, it's usually pretty straightforward to know what faces need to be selected to achieve the desired effect. If an adjacent can be extended/trimmed, then you're probably ok not selecting it. But for something like an attached fillet surface, those usually can't be extended and must be translated instead, necessitating adding the fillet surface to the Move Face selection.
I even tried importing a parametric model but the same too many faces need to be selected before any will move. The alternative is to 'offset' each sketch a couple thou. But that adds a layer of complexity and will probably 'break the model'. Or is there an another alternative?
THANK YOU VERY MUCH!!
Extrude can do it, but then I have to swich between Add and Remove, which is also not possible.
And moving it out past the max I'd ever need to go, then doing another move face back again as two features is a pain, and dose not feel very robust.
Extrude can take an negative number and/or a direction toggle, I just can't see why "move face" can't cope with a negative number. If you put a negative number in, you can see its limited to 0-500000.
Seems an obvious one, and actually not that uncommon a scenario.
Thanks for the suggestion.
https://forum.onshape.com/discussion/20793/move-face-feature-to-allow-for-negative-numbers-and-not-to-have-to-toggle-opposite-direction#latest
I guess it is a bit unintuitive, but if a user does not want to use negative numbers, they can use the toggle? It just seems like an oversight.
And as you say, for configurations, this is really helpful. Onshape seem to have forgotten about configurations. They are so great and only half a step away from being even more powerful. It needs a way to define rules that link configurations together, including Boolean config choices.
Best of both worlds!
@EvanReese I never seem to have answered this… sorry. I can't recall what the exact situation was, or even the model 2 years on, but I'm pretty sure I know why I needed it not to accept a negative number, and that was because I would have needed the feature to fail. And that was because the feature (and specifically it suppression) would ideally be controlled by 2 configuration tables using logic, or an expression of some kind, which it can't. And still can't 2 years later.
We still need a method to introduce some logic between tables, to control (and suppress) features, its got better with the Boolean tick box convert to expression, but suppression by expression is still not there.
Again sorry for the 2 year late reply, its only chance I stubbled across this again ! I must have missed the notification.
