linear repetition, occurence and variable
Hi All,
In a sketch, I want to do 4 linear repetition of Holes. 4 times with the sames parameters. But I don't want to have to change each parameter everytime I need to do a change. So i'm trying with variables, which works with dimensions but not with amount of repetitions. Is it normal ?
Thanks in advance.
Pierre
French - Draughtsman on SolidWorks (want to change) - New with Onshape. Don't need google to translate :D
    S1monS1mon Member Posts: 2,406 PRO
    Use feature patterns, not sketch patterns and you can use variables for the number of repetitions.
    pierre_bienfaitpierre_bienfait Member Posts: 4
    ok, thank you, will try this.
