I'm not able to boolean substract a sphere to a cube
tim_amslertim_amsler Member Posts: 4 EDU
I can't substract this sphere from the other 2 objects and I don't get why.
https://cad.onshape.com/documents/2810a55902c3cec73d2fd08d/w/45de7741debbdcd64fcb020b/e/59b0c74127b2ef341e528754
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    Does the sphere have to be a surface? Make it solid and it will work, otherwise use Split.
  • tim_amslertim_amsler Member Posts: 4 EDU
    Thanks, I already solved it with the resolver option.
