Is there a way to automate "copy specific part and select a tranform type for the user"?
In the Part Studio I am repeatedly moving my cursor to the same part (a washer) in the list, right clicking it, moving my cursor to the Copy option, clicking it, moving my cursor to the transform window, clicking the transform type drop-down menu, moving down to "Transform by mate connectors" and clicking again, then to select the first connector I am clicking the same hole of the washer as I've done several times, before I finally make a unique action where I choose a new location for the new copy.
If a script could just "Copy [Part 16], Select [Transform by mate connectors]", it would be awesome.
It would be nice if it could also select the first connector, too, but it would still be great without it.
Does this kind of copy script already exist, or can one be written? Would it be a lot of work to set up?
https://www.onshape.com/en/resource-center/tech-tips/tech-tip-using-the-replicate-command-in-onshape-assemblies
So I'm fastening them permanently. It might be a bad practice but it's the solution I'm currently looking to optimize.
https://cad.onshape.com/documents/09ca26e340e078cde1f6a833/w/f820843fbcd6a1bdc402bbdf/e/578479e4daa6ea234729722e?renderMode=0&uiState=644eb29fbf9ecb6db2c3d78a
They're in the joints. I've done a bit more on it since posting, learned a lot of different Onshape tools today.
I don't actually think this is a useful object, at least not with this kind of weight and dimensions. But it has already done a lot for me as a practice project.
See here: https://forum.onshape.com/discussion/comment/91279/#Comment_91279
That's lot of dedicated time and effort.
Ditto, S1mon's comments.
Trying to make changes/updates later will continue to be a tremendous amount of work.
That time would be better spent in the free learning center understanding assembly/subassembly functionality and understanding basic concepts.
https://learn.onshape.com/learn/course/introduction-to-assembly-design/assembly-interface/introduction-to-assemblies?page=1
https://learn.onshape.com/learn/course/introduction-to-parametric-feature-based-cad/what-is-cad/what-is-cad?page=1
https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/v/8217d6d96ccc324b8dd86160/e/4c62c06c4e0e4db3703a2d4c?jumpToIndex=1735
Your answers have done a lot to compensate for my poor methods.
