Retaining Ring Groove Custom Feature
TimRice
Member, Moderator, Onshape Employees Posts: 315
Easily create grooves for ANSI and DIN retaining rings with my new Retaining ring groove featurescript. Simply select a cylindrical face and a mate connector for the groove center and it will automatically find the matching groove size.
Add to your toolbar here (no need to copy): https://cad.onshape.com/documents/3678ac479f1de6df6bfbeec1/v/d602f6ae54e731080960c13b/e/c1e0e394d0acf27cd4e15506
Onshape, Inc.
Onshape, Inc.
7
This is fantastic! We've just been wondering two weeks ago if such a feature exists, and here you already have it!
Thanks a lot!
Florentin
https://cad.onshape.com/documents/3678ac479f1de6df6bfbeec1/v/eb900aa4f0ab5840bda17ee2/e/98f12ba5c18d6a0abdb796ec
Onshape, Inc.
Philadelphia User Group Leader
Either way, glad to know that we have retaining rings in standard content. Thanks - not sure how I missed that one!
It would be nice if the featurescript could place a new "intelligent mate" in each groove. This mate would know which size and type of retaining ring would fit in the groove.
After you place the part inside an new assembly, you can press the new "auto-populate all intelligent mates" button. For each mate, all retaining rings are placed with the correct size and position.
Do think this is possible?
The "auto-populate all intelligent mates" button could also be used to refresh all rings, in case the size of the grooves was changed. This would also be cool for o-rings
@AsaEE I wrote the feature initially so I may be able to update it. I will see what I can do.
https://thesmoothcut.com/
Nice going, I like this very much and have added to my list.
One small note. The groove material is left behind as a separate part. Was that intentional?
Interesting. I had one my first grooves in an existing document. One of the FS lessons, the material was left behind as separate part.
Just tried in a new PS and the behavior did not repeat.
I'm very new to CAD and I've been putting some assemblies together over the past few days using the many guides on YouTube from Onshape and the wider user community. I'm coming along slowly but I'm making progress at least. But I'm struggling with adding an internal grove for snap ring. I added this feature script but I'm a little lost on how to use it and wondered if anyone had done a tutorial - I've looked but struggling to find anything. I get an error something along the lines of the suitable retainer not found.
