Finding a measurement in Assembly
I am building a model of a shed, and I need to find a specific measurement in the assembly window. I need to know what length will bring the jack stud in the screenshot below to meet the top plate in dark blue. Please let me know if I am approaching this the wrong way, thanks!
https://cad.onshape.com/documents/f79f11d5cd86f79d77340d8b/w/ca0b3d6bebef0ee4abf52efa/e/10b033ea863946e4fb02d922?renderMode=0&uiState=644927f24d176d066982e2e9
S1mon Member Posts: 3,369 PRO
I took a quick look through your document. While you can approach things the way you've done, but it's really a mismatch between the power and capability of Onshape and the features you've used to achieve your goals. I would highly recommend you spend some time going through some of the learning pathways:
https://learn.onshape.com/learning-paths/onshape-fundamentals-cad
https://learn.onshape.com/learn/learning-path/top-down-design
https://learn.onshape.com/courses/frames-fundamentals
The most obvious red flag:
Sketch 1 through Boolean 1 could be done as one sketch and one extrude, or even better, you could use some of the top down design concepts or the Frames features to build all of your lumber in the context of the walls and structure so that miters and notches would be tied to the overall design. Using transform over and over like that is basically taking how things work in a non parametric modeling tool and translating that approach directly to Onshape. It's possible, but it really is wasting the power of the tool. It's kind of like taking a electric saber saw and using it manually like a file.0
Take a look at my second attempt and let me know what you think.
I am also looking for advise on how to approach adding the studs in the spaces highlighted in the screenshot below, as well as adding a coped butt jointed 2x4 in between the header and door stud on the left along the roof. I would like to do these with the frame feature. Thanks!
One thing I see is that the way you create the sketch plane for the Roof Area sketch is very strange. A more typical way would be to use the plane feature with an edge and an angle or with 3 points. Again, transform does have good uses, but for the most part, if you find yourself using it, there's probably a more parametric typical way that makes more sense.
