Publications: publish only 1 part of a multipart studio with it's drawing
Hi,
I would like to send a plastic part and it's drawing to a production partner. However it is a part of a multipart studio and the document contains many models, drawings and assemblies. Therefore I'd like to use a publication where I can put together the content which is used for that specific production partner only. I don't want to share the rest of the parts. However publication only let me add tabs and no parts only.
On the other hand I can put a single part from a multipart studio on a drawing or in an assembly. How can I do the same with a publication?
best,
Urs
best,
Urs
A workaround may be to create an assembly with only the specific part (as you mentioned) and link to that assembly tab in the publication, together with the drawing tab?
I would suggest you create an improvement request for this.
Another way may be to create a configuration that suppresses/deletes the parts, leaving the only part you want to view. I think you can select a configuration in a publication.
I'm aware of derive or insert a part into another tab or document. However it just kind of doesn't feel right.
a) I get more representations of the same thing which makes things more confusing (updating several documents or tabs etc.)
b) Which would be the original body for the drawing or assembly?
c) It seems like a step back towards traditional CAD(e.g. solidworks) where I needed to split a multibody into different files to make a drawing/assembly.
The fact that a multi-body system does not need to be split into files is the most unique and valuable feature Onshape offers. I don't want to destroy that.
I hope you understand my idea. What do you think of it?
open for your votings :-)
https://forum.onshape.com/discussion/20873/possibility-to-share-a-realeased-status-of-a-model-or-drawing-only#latest
