FS- Using mate connector as a plane for a sketch
ben_partouchben_partouch Member, csevp Posts: 158 PRO
Hi,
Can anyone please help with this? I know it's super basic. Yet I can't figure out the right code...
Thanks,
  • xTimRicexTimRice Member Posts: 61 PRO
    I think you’ll want to use evPlane on the mate connector: https://cad.onshape.com/FsDoc/library.html#evPlane-Context-map
    It returns a plane that you can then use in the new sketch.
    Handcrafted furniture in Boston
    https://thesmoothcut.com/
  • ben_partouchben_partouch Member, csevp Posts: 158 PRO
    Thanks Tim!
    It does't fail like before but I can't manage to see the sketch entity.
    var sketchPlane = evPlane(context, {
                    "face" : definition.location (the make connector)
            var sketch1 = newSketch(context, id + "sketch1", {
                    "sketchPlane" : qCreatedBy(makeId("face"), EntityType.FACE)
            // Create sketch entities here
            skCircle(sketch1, "circle1", {
                        "center" : vector(0, 0) * inch,
                        "radius" : definition.holeSize * 2
            skSolve(sketch1);
    I think I got it. Thank you @TimRice
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,909 image
    Always use newSketchOnPlane.
    Thanks @NeilCooke!
