Super Derive for parts which are not located at origin
AcomaAcoma Member Posts: 10
I am creating different versions of mechanical  elements (pneumatic connectors) in the same part studio. In another part studio I use super derive to ad these elements to my design parts. However, if the mechanical element was not created at origin, then I run into misplacement problems with super derive. Should I move every mechanical element to the origin? Placing a mate connector at the mech. element does not solve this issue.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,922 image
    Make sure you are using the latest official super derive and not somebody’s copy. This works with mate connectors.
