Rotating a sketch / other way to do this,
eric_carlstromeric_carlstrom Member Posts: 4
Hello!
Here's a pic of my sketch =
My idea is to have that circle & arc combo that I have up top also at those yellow circles. The problem is that since the constraints on the arc are horizontal, it doesn't translate to the angles versions on the sides.
Is there a better way to do the arc bit or could I rotate my sketch so that all 3 sections all use their own local horizontal constraints somehow?
I appreciate any and all help!
Cheers.
Eric
  • steve_shubinsteve_shubin Member Posts: 1,116 ✭✭✭✭
    https://cad.onshape.com/documents/1f170f1b74ea9aa70feafc7a/w/d5d15e8cda34c92796e00dc5/e/c85288137aa17cbceaedbb49
    Given a choice, I most of the time would rather do a feature patten, rather than a sketch pattern
    edited May 2023
    By the way, in the manner that I did the extrudes, if you try and boolean those three inner cylinders with the outer part, you’re going to run into problems.
    So you could either do a composite or there’s other solutions, such as doing an overlap of the inner cylindrical parts with the outer shell, or separating the cylinders from the shell. Or you could extrude the little wings up to the same elevation as the top of the cylinders and that’ll take care of it
    Added a second booleaned part studio
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,019 PRO
    Do it the way Steve showed.
    Why didn't you draw your part on the default planes?
  • eric_carlstromeric_carlstrom Member Posts: 4
    Thanks Steve!
    I apologize for the late response, but I've been swamped and unable to work on this. Looking at your sketch I instantly wanted to slap the past me. It really was not a difficult problem, even for me as a beginner but I must of gotten trapped in a box of my own making which made me unable to see this solution.
    I really appreciate the help and effort.
    Cheers!
    Eric
    … I must of gotten trapped in a box of my own making which made me unable to see this solution
    Happens to a lot of us
    Seems like I’m trying to punch my way out of wet paper bags more often than not at times
