Cannot extrude pin in Exercise: Creating Multiple Parts in Part Studio
I am trying to extrude the middle pin (Slide 10), but unable to select the middle circle. What am I doing wrong?
https://cad.onshape.com/documents/c497b920949d7e44727385a3/w/dd5e42207fe5a8e712a8564b/e/19da458d786b5ba62374e339
David_YL_Nguyen Member, Onshape Employees Posts: 149
It worked for me, you can have a look in the document I have attached. Sometimes it can be helpful to hide existing geometry or planes for your selections. Hope this helps.0
Might be that you have made a wrong selection or just need to flip around the extrude directions.
Is this what you are trying to achieve:
https://cad.onshape.com/documents/fcf7df200b0c75b7cdf94876/w/58b415b3c64f02de8428c22a/e/a4b736c17273c742ea5cfe7c
Best,
David
