Face on drawing of an angled part.
james_munrojames_munro Member Posts: 14
https://cad.onshape.com/documents/25025155be31feeb694041a4/w/eb6035960f3084c5335fad1e/e/d69b05a65009102afca18a0c?renderMode=0&uiState=64592509fb9d895c89609893
I have generated a drawing of the roof structure, but I want it to be a drawing face on to the roof, how can I specify this?
Thanks!
    @james_munro, try this:
    1. Select the face of one of your roof rafters.
    2. Type n (to orient the view "normal" to the roof surface
    Is that what you are trying to do?
  • james_munrojames_munro Member Posts: 14
    This is what I want but in a view on a drawing sheet.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,475 PRO
    You need to either create an "auxilary" view in the drawing or I would just create a named view in you model and use it on the drawing.
    I did what you suggested and named a view, thanks!
  • gareth_farringtongareth_farrington Member Posts: 13 ✭✭
    This has gotten me ore than once when exporting slightly angled parts to be laser cut. Named Views to the rescue!
