Why i can not split this Part?
niklas_thomniklas_thom Member Posts: 11 EDU
Hey,
I try to design a model rocket nose cone and i have a problem:
I want to split to nose cone in two parts. It should be like a box for the parachute. But split tool only works if i uncheck the keep both sides checkbox.
Thx for helping me!
https://cad.onshape.com/documents/cea691872fd303a938dac4de/w/3879130ba096b45d3b30f62c/e/3d5c72544f8a6740056dc092
  • S1monS1mon Member Posts: 3,746 PRO
    It's a little difficult to tell, since you didn't make your document fully public. No one can make a copy in order to fully investigate. That said, looking at a cross section there are some weird little gaps near the base where some of the features are not quite joining, and there's a separate part which is interfering at the top. Seems like some of these issues may be making your split fail.
  • niklas_thomniklas_thom Member Posts: 11 EDU
    Thx for the answer i managed to fix it.
