SHEET METAL CORNER
Member Posts: 7 PRO
Hi All,
I'm trying to model the grey shape below in without the large gaps at the corners.
First image shows what happens when I use a flange feature.
Another method was converting from a solid to sheetmetal part. This works on the orange test part well.
However, in the second image you can see it does not work for the grey part because the top flanges are all on the same face and the flanges segments can't be individually selected.
Thoughts?
