Extruding a circle on a curve part.
mario_darceuilmario_darceuil Member Posts: 113 ✭✭
Hello I wish to create a circle on the grey curved part and extrude it to make a short pipe about two inches long. I cannot create the circle in the first place. Which plane do I used; how do I sketch on the curved part?
https://cad.onshape.com/documents/8b2c487524aa4e51f139516d/w/1d5b570620afe590aefe987b/e/3849be1af01f7c5a402734d5
  • mario_darceuilmario_darceuil Member Posts: 113 ✭✭
    Thank you but I've tried your instructions and it never worked, please write instructions to do so. Thanks.
    Sorry, "Curved" part.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 943 PRO
    Creating an offset plane and then drawing and extruding a circle "up to face" would do the trick.
  • S1monS1mon Member Posts: 4,061 PRO
    Can you sketch what you want the result to be? It's not clear from your description or model.
    "Up to face on plane two" Please write the steps.
