Rounding values
Luc_ROLLANDLuc_ROLLAND Member Posts: 6
Hello !
I try rounding calculations,
PosMin=2.9cm
PosMax=5.5cm
#PosMin+(((#PosMax-#PosMin)/5)*2)
return 3.94cm
but I need mathematical rounding, so I write :roundToPrecision(#PosMin+(((#PosMax-#PosMin)/5)*2),1)
or
roundToPrecision((#PosMin+(((#PosMax-#PosMin)/5)*2)),1)
or
roundToPrecision((#PosMin+(((#PosMax-#PosMin)/5)*2)),1))cm
I hope 3.9cm
but I obtain an error !
(as with some others variants).
I don't understand where I'm wrong, but I'm newbee with OnShape ...
Please help me.
Luc
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 902 PRO
    Or if PostMin and PostMax have to have units, this would work.
    roundToPrecision(#PosMin/(cm)+(#PosMax-#PosMin)/(5 cm)*2,1)cm
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,968 image
    edited May 2023
    roundToPrecision only works with numbers, not ValueWithUnits, so you should use:
    PosMin=2.9
    PosMax=5.5
    roundToPrecision(#PosMin+((#PosMax-#PosMin)/5)*2,1) * cm
  • Luc_ROLLANDLuc_ROLLAND Member Posts: 6
    A little bit complex.
    Many thanks.
  • dave_boltdave_bolt Member Posts: 2
    Would be nice if this strategy was referenced in the documentation.
    I also found that #PosMin/ cm worked as well as #PosMin/(cm)
    I guess what is happening here is that #PosMin has units of cm, so dividing by cm gives a dimensionless value, or Number.
